condenser fan hums, condenser clicks, but no go
Old 08-31-07, 06:15 AM
C
Angry condenser fan hums, condenser clicks, but no go
Good day men
My unit is located on the roof of two story building. I have 220 all the way to the unit. the fan hums and cannot be kick started with a spin but does spin freely and does not feel hot. The compressor has a periodic timed click but will not kick in. The handler seems to work fine. This unit is three years old.
A valve cap is missing from one side of the coolant ports and 2 seperate repair men have worked on 2 seperate units on this condo complex roof in recent weeks.
I hate to be suspicious, but over the years I have experienced several failures in the 24volt to thermostat line shortly after repairs on this roof.
Any comments greatly appreciated
Old 08-31-07, 07:01 AM
Jay11J's Avatar
Did you check to see if you got 220v at and after the disconnect box?
Contactor not dirty or has spider or what not on it?
Old 08-31-07, 07:34 AM
C
Smile condenser fan hums, condenser clicks, but no go
Thanks for quick reply
Power from breaker and from cartridge style fuses on roof check out. i pulled and tested the cartridges and power to the units terminals. They look clean.
I have allowed the system to cool in case of a heat overload but makes no difference(overnight+ the system has been out one week)
Thanks
Old 08-31-07, 07:54 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
If the contactor pulled in then thats ok.
That would be it on and off with the klixon. Have you checked the start run capacitor . That should be for the fan and the compressor?????
also get caps to put on the schrader valves there for sure
Old 08-31-07, 08:32 AM
C
Hey Ed
I will check the capacitor. Kinda stormy here today so don't know i'll get on it( don't need to confront shock possibility from too many fronts.
I thought I saw 2 but will check again
thanks
Old 08-31-07, 08:40 AM
Ed Imeduc's Avatar
Wink
Most units just have one capacitor in them for a start run . Its a dual one for the fan and compressor. So check ,if so wires from the fan and compressor go to it
Old 08-31-07, 11:26 AM
D
It sounds like you're getting power to the compressor motor. If the fan motor is cold but the compressor is hot [physically to the touch, not electrically] then most likely the fan motor is bad. If both are hot to the touch then most lilkely the capacitor is bad. If you determine that the motr is bad then repalce the motor capacitor also, eiher by piggybacking a new capacitor to the existing one or repalceing the dual capacitor. Some of the websites that sell parts have very good tutorials about capacitors.
Old 12-11-07, 12:37 PM
C
done deal
Dropped the ball on the a.c.. Went on holiday. Got back from holiday. Read over Q&A from my posts and a few others. Pulled the capacitor, found small bulge, replaced. Tested the 24 volt + contact points. turned power back on and away she went.
Thanks to you all
