water blowing
water blowing
help ! i have water on the floor under my air handler !!!!
the drip pan and drain pipe are working perfectly. i can pour water in the drip pan and it flows out of the pipe.
but........(with the panel removed) when i turn my ac on,,the fan causes the water to blow out of the pan !!spalshing! everywhere!.... .. with the cover on, it dribbles out of the side cover , from splashing and blowing i think.
my question...can my coil be so clogged that it is forcing the air thu the water on the drip pan? or ???
any ideas????
help
and.....if my coil clogged..wouldnt the bulk of the crud be on the INSIDE of the coil? (inside the "A")...ive read some on cleaning coils,,and they all show it being done from the outside with a brush or vaccuum brush. will that get it clean?
any ideas????
help
Last edited by theranster; 10-06-07 at 07:38 AM. Reason: added more probles/questions
A clean coil (both sides) is absolutely essential for proper drainage. Additionally, the pan needs to be clean and the drain lines clear. It's good practice to blow them out whenever the coil is cleaned. Also check for a rusted out or cracked pan.
Be careful when cleaning the coil. Do not damage or bend the fins. Bent fins do not drain properly and restrict air flow.
