condensing unit fan replacement
Old 11-15-07, 09:23 PM
V
Question condensing unit fan replacement
trane condenser fan quit and the replacement fan is a universal replacement which has 5 wires and comes with a capacitor, the old fan motor only has 3 wires.
Need help
Old 11-16-07, 03:01 AM
mattison's Avatar
Just wire it by the diagram on the motor.
Old 12-24-07, 02:03 PM
pflor's Avatar
What are the colors of the wires?
Brown is often used (but not always...it depends on the motor manufacturer) for the capacitor connections ( a standard capacitor has 2 terminals, so there should be 2 brown wires)
This motor is likely a 220V single phase. Likely a black and a red are for the 220V power feed...or a black and an orange for 208V (double check on the motor nameplate for correct color to use, red or orange).
Does the motor have a ground wire? if so, it should be green, and that gets connected to a metal screw on the chassi of the unit.
hope this helps
