Changing from R-22 to R-410a
Old 01-03-08, 12:04 PM
C
When replacing a R-22 split system heat pump with a R-410a HP, can the refrigerant lines be re-used if properly cleaned with Nitrogen?
What are the possible dangers of reusing the existing line set?
Thank you in advance for your answers.
Old 01-03-08, 12:23 PM
C
I just answered my own question. I found this article, Link:
http://www.contractingbusiness.com/2...se/77425/Issue
It makes a very strong case for replacement of the line set but goes through what to do if the replacement is near impossible.
Old 01-03-08, 12:31 PM
mattison's Avatar
Unless it's just impossible you should replace the line set. The article you posted tells it all.
