Need Answers?
Old 02-18-08, 04:34 AM
V
Need Answers?
Need Answers?
I have a job that unfortunately thieves target almost nightly, "Job Security". Anyway, someone stole one of my 5 ton Rheem Classic Heat Pump Condensing coils along with all the copper all the way up the outside wall. My company had a 5 ton Payne Condenser setting up from a building that was demod recently, but it's not a heat pump. My ?? is, is it possible for me to run the Payne unit in place of the Rheem even though it's not the same brand, or a heat pump, but they are both over 5yrs old which makes them both 10 seers??
Old 02-18-08, 08:41 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You should get by with it. You wont have the same seer out of it. You will only have it as a AC unit. Lots of codes now call for the condenser unit to be anchored from the inside of them to a cement pad. Also metal cover over the line set on a wall.
