Goodman AC Problems
Old 04-02-08, 11:24 PM
F
Goodman AC Problems
I need help.
I currently have two 2 ton Goodman HVAC units in my home. I realize they are considered to be below builder grade but they have done a great job thusfar. They are 8 years old. One up and one for downstairs both 10 seer. The house is a 2000 sq ft house. The up unit is no longer cooling. The condensing unit fan works and air blows into the upstairs but no cooling.
A repair man came and refilled with freon and went on his merry way. Later that evening, the cooling stopped. He came back out and said the A coil was leaking. He called back later with a quote for 700.00 to replace the acoil. He said he could not get a 10 seer coil anymore and that he would have to replace the 10 seer with a 13 seer. Now, he also stated that if he were to use a 13 seer coil, the warranty would be worthless unless I replaced the condensing unit. His quote for the a coil and a new 2.5 ton Goodmaninstead of the existing 2 ton
back later with a quote for 700.00 to replace the acoil. He said he could not get a 10 seer coil anymore and that he would have to replace the 10 seer with a 13 seer. Now, he also stated that if he were to use a 13 seer coil, the warranty would be worthless unless I replaced the condensing unit. His quote for the a coil and a new 2.5 ton Goodman instead of the existing 2 ton one would be 1950.00.
My questions are as follows:
a. Is his quote high for the a coil replacement?
b. Is his quote high for the condensing unit?
c. Can we just replace the a coil and not the condensing unit, since the condensing unit is working?
d. If so, will we need an expansion or fixed metering device?
e. Why can we not get a 10 seer coil anymore?
Any insight would be greatly appreciated.
Old 04-03-08, 01:05 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
First there Id get 2 more bids for the job. Its the GOV that has made the SEER of the units go up and companys cant make the old lower SEER units.
Old 04-03-08, 01:53 PM
F
Goodman A coil issue
Thank you. I gather you think that 1950 is a bit high for a coil and condensing unit replacement?
Old 04-03-08, 04:11 PM
pflor's Avatar
Labor varies widely, the is no right or wrong here. The prices you've been given are not unreasonable.
But as Ed says, go and get at least two more bids.
