stay with r22 or upgrade to R410A
Old 04-11-08, 02:42 PM
K
I have a 2 ton r22 bryant outside unit and and a International comfortmaker air handler. The outisde unit is shot. the air handler is about 4 years old and is in real good shape. my question is should I stick with r22 unit and keep my air handler or should I replace both units with R410A unit
If I stay with r22 what would be a good reliable cheap unit?
or
If I go with R410A what would be a good reliable cheap unit?
also what is the life expectancy of an air handler?
Old 04-12-08, 10:20 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
We try and stay with the R22 it will be around till 2030.
Might read http://www.toad.net/~jsmeenen/freon.html
about what is what about R22 freon.
If you will be in the home say for 10 years go for a good a good unit with a 15 seer on the unit. That means its best to get a match set inside and out. Not add on to what you have.
