Trane spilt system model 2TTR2030 (2006/2007)
Old 05-07-08, 04:22 AM
L
Can the air handler with this system be mounted horizontally? It's being removed from a home where it was mounted vertically. This is a heatstrip and not a heatpump, correct? Thanks for any help.
Old 05-09-08, 07:36 AM
pflor's Avatar
The M/N you have given (2TTR2030) is for the outdoor unit only. You need to provide the M/N for the inside unit in order for us to be able to know if it is a multi-position unit.
The system you have is indeed NOT a heat pump.
