Command-Aire Thermostat Change-out
Hi, I have Command-Aire model SWP 351EA water source heat pump in my apartment. I want to replace the original thermostat model CM260A with a Totaline Model P474-0100. This one has auto change-over feature from cool to heat and heat to cool.
The original is a four (4) wire. Can anyone tell me the correct connections to use on the Totaline?
Wiring
Hi Jay11j,
The thermostat wiring to heat pump is as follows:
Rc is connected to R (Random Start [24 VAC])
G is connected is connected to G (Fan)
Y is connected to Y2 (Compressor)
O is connected to Y1 (Reversing valve)
There is also a jumper on the thermostat between Y and W.
The heat pump is a water source type which provides both cooling and heat. The original thermostat was a manual change over type. The Totaline is an auto changeover type.
I hope the above info helps.
R to R (may need a jumper wire at t-stat.)
G to G
Y1 to O
Y2 to Y
Hello MB300, I see you helped someone else out a while back with a Command_aire thermostat. I want to install a new programmable White-Rodgers thermostat and cannot figure out the wiring. My existing thermostat has R (red wire), G(green wire), Y1 (blue wire), Y2 (white wire) terminals. The new White Rodgers unit has O/B, Y, G, W2, C, L, R terminals. Can you help? Many thanks, Fred
Looks like MB was assisted by Jay.
Can you post the connections at the heat pump?
It looks like their Y1 was connected to O at the heat pump. If this is the case your new thermostat will support your system.
Hello Jay, I see you helped someone else out a while back with a Command_aire thermostat. I want to install a new programmable White-Rodgers thermostat and cannot figure out the wiring. My existing thermostat has R (red wire), G(green wire), Y1 (blue wire), Y2 (white wire) terminals. The new White Rodgers unit has O/B, Y, G, W2, C, L, R terminals. Can you help? Many thanks, Fred
