A/C Trouble
A/C Trouble
I have an problem that only occurs sometimes. The inside unit does not kick on all the time when the outdoor unit does causing the outdoor unit to freeze up. Seems it happens when it is hotter outside because it works fine during the first of summer and end of summer. If the fan is left to the "on" postion everything works fine because the fan is always running.
Any Ideas would be helpful
You did not mention the size/brand or age of your air handler so it will be a bit hard to guess but I can tell you that if this is a newer unit I would change out the blower motor capacitor as that is a common failure item. Change the capacitor right now and let us know what you have.
