fan motor wiring
Old 06-07-08, 11:01 AM
K
fan motor wiring
I am in the process of replacing my fan motor on my condensor. i took the old fan to grainger and they gave my a replacement.
when I brought it home. The old fan had 4 wires and the new one has 5 wires. Can some help with the new wiring?
below are the wiring diagram for the both motors
old motor
red/whit------cap
brown--------line
blk-----------
new motor
brown/wht----cap
brown--------cap
purple--common----L1
black--------------L2
green----------ground
(optional 3 wire connection)
brown/white-----insulate
brown-----------cap
purple--------L1
I tried the optional 3 wire connection, below are my setup. When I tried this one, the fan didnt work
old-------------new
red/white------brown
brown---------purple
blk------------brown/white
Old 06-07-08, 02:13 PM
K
old motor
red/whit------cap
brown--------line
blk-----------
new motor
brown/wht----cap
brown--------cap
brown-----------cap
purple--------L1
old-------------new
BTW I was going to use the old capacitor it has 3 poles going to it. Is this possible or do I need to get another capacitor also?
Old 06-08-08, 03:02 PM
W
5 wire fan
It looks like the only wire added with the 5 wire fan to the 4 wire one you are replacing is the ground. That would let you wire it the same as the old fan and just attach the green (ground wire) to a new screw terminal someplace in the box.
