Outside compressor tripping breaker
Old 06-09-08, 01:32 PM
D
I went to turn on our A/C last week for the first time since last summer, and after I turned on the inside thmstat, it immediately tripped the A/C breaker. I reset the breaker a couple times but the compressor keeps making a buzzing sound and then trips the breaker.
I did a continuity test of the two compressor fuses and they are fine (0 ohms), but I'm not sure what else to check.
Could the capacitor be bad?
I need to get this working ASPA since my wife is 8 months pregnant and I can't get a service person out for a couple of days due to the heat wave right now.
Thanks,
David
Old 06-09-08, 01:51 PM
E the P's Avatar
Thanks,
David
Double check your electrical connections, they may be loose.
Old 06-09-08, 02:32 PM
D
which connections?
should I check the connections at the outside fuse box or inside the compressor? From what I can tell, everything is fine.
