HELP! The AC outside is running, but not inside
We had a few storms a few days ago after the storms we woke up to the AC not working. We checked the breakers and none were tripped. The outside unit runs when we turn the system on, but nothing happens inside. We tried the fan and it doesn't blow either. IT IS 98 degrees here we are strapped financially and I would be so thankful if someone could help us figure this out.
Stacy
Stacy
Anyone know how to check
if it is a fuse inside the air handler (is this in the outside unit or in the inside of the home?) or a bad blower motor
Our system is a Heil ACS024A2C1
Could be quite a few things. You could have even shorted out the thermostat with electrical storms. Someone's going to have to troubleshoot and check the voltage everywhere with a meter.
Great I am going to have to find someone to do that UGH!
