Contactor wiring ?
Old 06-17-08, 08:51 AM
E
Contactor wiring ?
My Coleman Evcon A/C contactor needs replacing. The new one is identical EXCEPT the T1 an L1 wiring posts change sides. Question is, should I move the wires to that side too or wire them to the T2 an L2 posts without having to change the wires original wiring shape. Thanks for any info, Eddiebuck
Old 06-18-08, 09:45 AM
HVAC Mech.'s Avatar
With 230V. single phase it wouldn't make any difference.
Polarity doesn't matter with AC voltage, as long as you keep the neutral separate, you can switch the 2 supply leads to either L terminal, and the 2 supplied leads to either T terminal. Nothing is going to reverse rotation.
Tom
Old 06-18-08, 06:23 PM
Jarredsdad's Avatar
Ditto
THink of it as installing a light switch so it says No instead of on. A little backwards but is doeas and will continue to work.
It really is just a switch.
Old 06-19-08, 09:15 AM
E
It Worked!!!
Thanks folks. It worked by wiring the L1 to the L2 and T1 to T2 and not having to reroute the wires. Thanks A BUNCH, EDDIE
Old 06-19-08, 12:29 PM
HVAC Mech.'s Avatar
No problem, the bill is in the mail... No charge for travel time either!
Tom
