Rheem AC unit only blower working
Old 06-21-08, 04:49 PM
R
I have a Rheem AC/Heat unit that is pretty old. I have to keep resetting the onboard breaker. The breaker has a small reset lever that you can push in to reset it. Every time it trips, the compressor turns off and only the blower fan works. I can reset it but than it just trips again. The time the compressor works when I reset it is about less than 1 minute and the time shortens the more I reset it. It will work a little longer if I leave the unit off for a while.
Old 06-21-08, 09:45 PM
Former Member's Avatar
Received 1 Upvote on 1 Post
Could be the high limit kicking out a few more details would help tremendously. Unit brand etc etc etc bring on the info anything you can think of including the area and outside temps etc etc
