Central unit not working
I am trying to find a replacement motor for my unit, its a GE motor, mod. 5KCP39BG V. 208-230 1PH Amps .75 HP. 1/10 CAP. 5.00/370 Rpm. 1100 Equip MFRS #HC33GE232A thats all the info off of the motor when I turn the AC on the motor doesnt come on so I am assuming its the motor any one know where I can find a replacement from.
This might work, don't know your rotation.
http://www.grainger.com/Grainger/items/4UY86
What is the model, serial number of your unit?
MAnufacturer?
MAnufacturer?
MAnufacturer?
MAnufacturer?
Model is incorrect. 38TKB0**310 missing numbers there.
But being a 1993 unit I may not get full spec at carrier site.
Take your old one to a supply house and match it. HP, volts, RPM (very important), amps (important). Might find a reversible universal, 50/50 shot on rotation.
No I didn,t hear the comp. running
You started out looking for a fan motor. Here are the part numbers for what I would change here if the motor were really failed.
26 P291-4553RS CAPACITOR-DUAL
40 HC33GE233 MOTOR-FAN
41 LA01RA015 BLADE-FAN
Is the compressor coming on? And not the fan?
If you kill power inside and out, wait 5 minutes and turn system on (with a person outside at outdoor unit) the compressor will be heard running without the fan. If nothing runs, time for service call.
Bill of materials shows compressor time delay, which could be bad keeping everything off.
BOM also shows Motor Master which controls outdoor fan, which could also be bed.
Service Call.
Service Call.
