trane xl80
trane xl80
I have a trane xl80 and my blower fan will not shut off.
I had a lightening strike about a month ago, I had a lightening strike last summer also, and it fried the ciruit board where the a/c would'nt work at all.
This time the a/c works just the blower won't stop unless I turn the a/c off at the wall.
I have changed the t,stat
Any help would be appreciated
Try taking off the G wire at the furnace board, and see if that stops.. If it don't stop, then you may have a board issue again.
I would check with your insurance company and see if they cover power surge/lighting strike.
Thanks for the reply Jay,
I tried the G wire still have a running fan.
the circuit board has a red light on it, and it is flashing in six increments at a time, I cannot find any info on what the trouble code is Any ideas?
The Code info is on back of your blower door.. I just glace at mine.. (Mine is a 90% furnace), and 6 means bad ignitor, or 115volts power is reversed.
Take a look at your chart. may not mean the same.
