New Compressor. Charge problem?
Old 07-27-08, 07:05 AM
shayneb's Avatar
Recently, our A/C broke. A shorted compressor motor in the outside condenser unit was to blame. It is a Goodman CKL42-1A, which uses a Copeland compressor and we engaged an A/C serviceman who does weekend work to swap it out and get it working correctly. The installation has been less than satisfactory because the compressor unit does not always start when it should - the compressor sometimes starts along with the fan on the condenser unit, and sometimes only the fan. It took from yesterday noon to last night to reduce the house temperature from 74 to 69 - this usually happened within about 30 minutes.
The old compressor is a Copeland CR42K6-PFV-230 and the new unit is a CR41KQ-PFV-980WB. I have the specs from emerson as PDF files and can send if required. Sound close enough? The specs on the units seem very similar. We don't need the heater though on the new one so it is left disconnected. Very close physical footprint and it bolted in OK.
He swapped out the compressor unit after he removed the R22 with a special unit that attached. After evacuating the old R22, attached a vacuum unit, then disconnected the old compressor, re-connected the new one and welded the new pipe-work in. He leak tested with a spray foam bottle on the newly welded pipes, found one leak and re-welded it. No nitrogen inserted to test for leaks though.
After obtaining a vacuum, he then put in the R22 in the system. The amount of R-22 put into the system was not measured and this was a red-flag for me. I believe the specs are about 6 pounds but he had no way of really knowing.
The unit was started and seemed good. Cool air started flowing into the house and there was a 17 degree variance between house temp and cool air that was in the late 50's. The temp in the house was about 74 to begin and we had the thermostat set to 66 to get it cooling. After a short while and his last minute adjustments, the compressor tried to start again- we heard the short buzz but the compressor unit did not start but the fan on the condenser unit mounted above the compressor did.
After much fiddling, he measured the compressor unit and told me the internal overload in the compressor was coming on (opening the internal protective circuits?) apparently to stop the compressor from overload. Weird. Then he evacuated a little R22 and tried again. Still no good.
After an hour or more he departed saying the compressor was probably bad. Remembering it is brand new, purchased from a reputable local agent of Emerson this seems strange.
The thermostat inside was set to 69 and reading about 74 wen we turned the a/c on about 1 or 2PM. It came down only a degree every few hours. Overnight the temperature in the house has come down to 69 as it should, but we have a cycle of the condenser sometimes running without the compressor running and sometimes with.
We were shown that the compressor unit draws 16.2 amps running and I was told that the pressure is 210 PSI and the suction side is 60PSI. I do not know what the grade or spec of the coil in the basement where the ducting and furnace are, or whether that even matters as with the old compressor it worked just fine.
So we are left with the new compressor installed, the remainder of a brand new 30 pound bottle of R-22, and an A/C that "nearly works" properly, but the compressor not always starting is of concern. When the compressor tries to start the fan outside runs for a period (as if it is functioning), then the compressor kicks in, cools and turns off.
I am not an A/C expert, but I have done some reading online and thought about what the potential causes might be and possible fixes.
1. When the compressor was installed, could the unit have been damaged by his welding (overload protection opening periodically not allowing compressor to start?) He spent a long time heating the pipes. I solder and weld myself and it took him a long time heating pipes on a nearly empty bottle, which he had to go and replace. Could heat transfer have damaged the compressor?
2. Need to install hard start kit? He did try another capacitor but it made no difference. He tried what he called a hard start kit, which just seemed like a different value of capacitor, but that made no difference.
3. Could the charge be wrong so the system is out of balance and causing problems? From the reading I have dome online, it seems there should be a scientific approach to charging the system. Would a wrong charge cause the compressor protection to cut in.
4. Could is be a power supply thing? The lights flicker when the compressor unit starts. Unlikely but possible?
I am looking to work with an honest and competent service tech who won't rip us off, hence all of the detail above.
Old 07-27-08, 07:14 AM
The Real Deal's Avatar
Hi!
First - you dont need to weigh in refrigerant to have it correctly charged. (unless its a critical charge system like a refrigerator ).It does not seem to be overcharged by what pressures you mentioned(however superheat and subcooling would be nice to know)
It is possible at first glance of your post - you need a hard start kit for this "New" compressor. It may not be designed to start against certain conditions that your unit may present. The power flickering light thing is a key indicator of needing a hard start kit.
Put a hard start kit on right away - Its doesnt mean that the tech did anything wrong - just needs to finish the job.
Oh, the nitrogen thing - well its nice to check for leaks but in a real sense it should have been used as the tech brazed the lineset to prevent flaking contamination which will be caught by the "New" liquid line filter dryer (a suction filter dryer too... if the old compressor was a "Burnout") he should install! (Hopefully it doesnt jam up the orfice or expansion valve - unlikely!)
Old 07-28-08, 03:59 PM
Jarredsdad's Avatar
Dude knew just enough...To be very dangerous.
Not bleeding nitrogen through the syatem while brazing is going to always cause problems down the line.
Didn't pressure test with nitrogen? What was used? R-22? Against the law to leak test with refrigerant.
"After obtaining a vaccuum" how many Micron was this vaccuum?
You never cahnge a compressor without also changing at least the liquid line drier. Add a suction drier just to be safe if you can fit it easy. If it was a burn out on the old compressor, fit the high acid suction drier in somehow some way. <---That is a period. <--That too.
NEVER ever change a motor OR compressor without also changing capacitors.
Should the guy had had a scale he could have wieghed the charge out and put the same new (new R-22) back in and checked if it was correct.
Now You are where You are. Tried to save cash and it's still hosed.
Where to go from here is to call an actual company. Explain the situation.
Also explain that the old and new compressors take a 189-227 Mfd 330 volt start capacitor (Copeland part 014-0058-00), and Potential relay (part # 040-0166-27).
The old compressor took a 40 Mfd 440 volt run capacitor.
The new one takes a 50 Mfd 440 volt run capacitor.
Start with those components.
Were I the Tech tasked with this call I would change the start/run components. Remove and filter the R-22. Change liquid drier, add suction drier. Filter R-22 back in and check charge.
Done.
