System won't turn off with thermosatat temp adjustment ( Goodman system)
Furnace is a Goodman GMP-075-3 1998
A/C condensing unit is a Goodamn 2 ton 10 SEER unit 1998
It is now the middle of a hot summer . The system is cooling fine but a problem has developed where the A/C and fan stays on regardless of the thermostat setting . I can only tun it off by placing the switch thermostat in the off position (between heat and cool ) . I suspect that is probably a bad control board or thermostat . How do i diagnosis this further (and repair) ? - Thanks
Edit -
Someone on another forums suggested to me that if is still runs when the green thermostat wire is removed then the control board is bad . ( which is the case ) .
I plan to order and change out the board with an aftermarket replacement type board which fits several models of Goodman furnaces ( ICM280 about $75 ) . Anyone familar with these .
A/C condensing unit is a Goodman 2 ton 10 SEER unit 1998
It is now the middle of a hot summer . The system is cooling fine but a problem has developed where the A/C and fan stays on regardless of the thermostat setting . I can only tun it off by placing the switch thermostat in the off position (between heat and cool ) . I suspect that is probably a bad control board or thermostat . How do i diagnose this further (and repair) ? - Thanks
