ac fan surging then stopping
I have a fan problem.. the outide unit is working fine but the blower was kicking on and off inside now its just off. I can turn the switch from auto to on and nothing happens. I have even tryed to free spin the fan with switch in on position nothing. when i 1st noticed it i shut it off at ( therm) for a few min.s then cut it back on it ran fine for about 10 mins then starting kicking on and off. I cut off again for a few then back on and now nothing the outside unit comes on but o air flowing in house.
well taked with ac buddy and checked capacitor and thats fine. have put therm. back to run and fan is on to see if motor is over heating and causing the prob. will get back with answer.
Air Conditioning Repair
If your fan is stopping with a good capacitor and you don't have any undo load added to it you have a motor going bad you may be able to clean it and lubricate to get it running but most likely you need a new one
