Kw rating4-ton tempstar
Old 09-12-08, 06:20 PM
I need to install a stand-by whole house generator for elderly parents home who live in Gulf Coast of Mississippi.
I need to get a general idea of what the KW demand for a 4-ton tempstar. The unit is 5 years old and I can't read the spec plate.
Any general ideas from professionals
Old 09-13-08, 05:02 AM
Air Conditioning Repair
The information plate won't help you anyway as you can install various heat kits in a unit so you will need to look at the heat kit itself but you are probably looking at somewhere either side of 15 kw.
Old 09-13-08, 10:59 AM
Jarredsdad's Avatar
I don't think I would worry about A/C if the power was out. More, refrig, lights, tv. And here, my well pump.
But, that's Me and doesn't answer your question.
What you'll need is a volt/ohm meter and an amp meter.
For each elec appliance you expect to run on the generator you'll need voltage and amperage readings.
Amps X Volts = Watts.
So if I have a 208/230 volt A/C rated at 20 amps (just picking numbers), I'm looking at 4160 and 4600 Watts respectfully.
Using real world numbers, say the unit is found to have 221 volts supplied and actually draws 13.2 amps in steady state operation (after say 10 min run time). This is 2917 Watts or 3 Kw, add a little fudge every time.
To make it even more tricky, you also have to worry about Inrush, or the starting amps when the unit turns on.
Using the above example, with 221 volts supplied, say when the units contactor first pulls in the amps spike to (pick) 39.7 amps. That's 8773.7 or 9 Kw just to get the thing running.
You will need a generator that can handle that sudden spike and provide the current to get it running. And that's just the outdoor unit.
As Mike pointed out you could have 5, 7.5, 10, 15, or even 20Kw heat strips in the airhandler.
You need to decide what you want to run off of the generator. Add all Kw's up, add a few helpings of fudge and go from there.
Maybe easier to find a standby generator company to evaluate if you truly want to run the entire house on a generator.
Old 09-13-08, 05:37 PM
Why A/C is important
Elderly parents and scorching heat with saturating humidity during hurricane season along with medical equipment. If it were just a few hours or a day with out electricity I would just use a 12,000 btu & maybe 6000 kw portable. Unfortunatly these storms can cause so much damage to infrastructure it can be weeks w/out power. Gasoline often is unobtainable and large quantities are difficult to store and maintain.
Additionally, their home has never lost access to natural gas during even the worst storm so that fuel appears to be the best alternative and most dependable.
Old 09-14-08, 06:29 AM
G
Due to age and physical considerations, You may be interested in this site.
http://www.briggsandstratton.com/eng...rator_systems/
These units are available in diesel and Have automatic transfer switches built in. They will have approx 20% standby capability which will tackle your motor starting loads.
Your parents would only notice a blink before power was restored.
This may be more pricey than you cared to spend, but would offer ultimate protection for them.
Old 09-14-08, 10:57 AM
G
The following site will give step by step instructions on selecting the gen to meet your individual needs.
http://www.homegeneratorsystems.com/buying_guide/se
Old 09-18-08, 06:34 PM
Well done
Thank you, It should have been so obvious
Old 09-18-08, 07:06 PM
Jarredsdad's Avatar
Sometimes yes, sometimes no.
Here you have a bunch of brothers and sisters to offer opinions and input to help make the best decision You can make.
Be strong, go forward.
