Safe to run
Old 11-05-08, 08:45 PM
R
Safe to run
Hi
my window AC [Kenmore 6000 btu] was left in the back yard, three or four months ] exposed to rain and weather. Is it safe to re install and run it or is there the risk of an electric short or shock if touched, as the rain may have damaged some component?
Thanks
Old 11-06-08, 03:11 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
I would suggest that if it has been indoors for a long period that you ensure it is unplugged and open up the electrical box on the front of the unit and look for signs of water damage.
If it was sitting in its noemal position water infiltration would be minimal.
As a test you should operate it for a short while on a GFCI recptacle or if you do not have one buy an extension cord type and operate it continuously on this.
Old 11-06-08, 09:26 AM
HVAC Mech.'s Avatar
You might take the outer case off and check for animal or insect nests, particularly in the blower wheel and electrical box. Wouldn't hurt to clean the coils while it's apart, too. I prefer an alkaline coil cleaner and water blast, being careful to direct the spray in the perpendicular so you don't bend the fins. And wash the filter...
Old 11-09-08, 06:42 PM
R
I tested it pluged to a GFI did not trip and check with the ommeter no shorts detected .Thanks so much
Old 11-09-08, 09:42 PM
Air Conditioning Problems
I would still clean it while you have it out it will never be an easier.
