reem hvac exterior unit
The fan on my Reem heat pump cut the purple and yellow wires and I dont know which wire connects with which. On the fan motor it reads 'Rotation Instructions' then one column reads 'CW, shaft end - purple to purple, yellow to yellow'; and a second column reads 'CCW, shaft end - purple to yellow, yellow to purple'
I figure it's clockwise or counter cw for the fan rotation, but how do I figure out which way it spins for the correct wire connections? If ccw, which purple goes to which yellow?
Can't help you with the wires.
Delta
