Hot Bedroom
Old 01-17-09, 06:50 AM
N
Exclamation Hot Bedroom
I have a 2 story house with 4 bedrooms upstairs. Two ac/heat central units one for the upstairs and one for downstairs. The bedroom right next to the central unit always seems to be too hot. In the Summer it does not get enough cold air and in the Winter it heats up before any of the other bedrooms have done so.
What can I do to ensure this bedroom is useable? Thanks,
Old 01-17-09, 07:13 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
If duct was installed correctly you should have dampers in the duct that you can open and close to adjust the air flow.
Old 01-18-09, 04:22 PM
you can install a motorized louver that fits right behind the exsisting register grill 24V control with a stat totally independent from the unit except the air.set the stat and when the room hits the setpoint the damper closes off....cooling wise you should be frezzing in that room during the summer?
