Best Trane Weathertron heatpump stat replacement
Old 01-29-09, 12:08 PM
C
I would like a digital stat, nothing to fancy to replace my Trane weathertron with aux. heat , there seems to be a few to choose from.
Thanks
Old 02-02-09, 01:32 AM
user 10's Avatar
Received 57 Upvotes on 50 Posts
There are consumer grade heatpump t-stats available at big box stores. (Honeywell is the best - make sure it's compatible with multi-stage equipment)
However, heatpump manufacturers used to have proprietary wire labelling schemes. If available, consult a service manual or wiring diagram to determine which wire controls what. (Common(C), power(R), reversing valve(O/B), outdoor unit contactor(Y), aux heat (W2/E/Aux), fan(G))
Old 02-03-09, 06:42 AM
Jay11J's Avatar
The Honeywell RTH 7000 series will be the best t-stat from retail stores.
Do you plan on using the stat's set back for your heat pump?
