Chiller with HCFC 404A
Old 02-12-09, 03:11 PM
R
I have a chiller with 3 compressor to cooled chilled water to sub-freezing temperature of -24F. While my discharged pressure is 165 psig, the saturated temperature should be 76 slightly higher than my condenser water about 60~66 F. However, I measured the actual temperature reading on my discharged piping it is almost 165F instead on 76F. Why does my discharged temperature is high?
Old 02-12-09, 03:22 PM
might have to check the liquid line just out of the condenser for that reading.....the pressure will be the same as your discharge, but the state of the freon has gone from hot gas to a liquid with temperature change.
Old 02-12-09, 03:50 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Hello Rock1984,
To be asking a question like this you will be working on a commercial refrigeration sealed system and we do not offer assistance in this area.
Repairs of this kind in many areas need to be performed by certified technicians.
Please read this.
