HEAT LOAD CALCULATION & 1TR of refrigeration
Old 03-20-09, 04:22 AM
N
Question HEAT LOAD CALCULATION & 1TR of refrigeration
If I want to calculate the tonnage of Air conditoning in sinagle or multistory building. How can I calculate it.What is the right defination of 1Tonn of refrigeration.What is the benefit of subcooling in vapour compression cycle.
Old 03-20-09, 07:10 AM
One ton of refrigeration is 12,000 btu's and subcooling is just referring to the amount of temperature difference of a substance (a liquid for the purposes of this discussion) below the temperature at which the gas became a liquid (dew point/temperature at which it precipitated).
We use this as a measurement to make sure that whatever metering device is being used is receiving liquid as these metering devices are designed to control only the flow of liquid refrigerant
