outside compressor fan runs hot for a couple of minutes then quits
Old 04-01-09, 04:11 PM
B
The fan motor on the outside unit of my heat pump runs for about two or three minutes then stops.
I've replaced the cap, then replaced the motor with an identical new one, still does the same thing.
It is an old a/c but still cools well when it runs. Called a local service tech and he told me the motor was bad. Said the motor was over-amping, pulling almost twice as many amps than it should. I called the place where I bought the motor and they insist the motor is good......... Is there a way to bench test one of these motors to see who's right??
Old 04-02-09, 07:36 PM
C
What is the voltage to the motor?
Is it the correct size capacitor?
Double the amps sounds like half the voltage.. do you have one leg of the motor wiring grounded?
Meaning the motor is running off of 110v instead of 220v?
Does the speed of the motor look slower?
Old 04-04-09, 06:59 PM
Jarredsdad's Avatar
Sounds like someone did have a bad motor and bought a not exact replacement. If the motor is not exact it will over amp trying to drive the attached fan.
Make, Model, Serial of unit?
