High side and Low side on A/C unit [Post moved to correct forum]
Old 04-25-09, 08:07 PM
P
How do i find out which is the high side and low side on my home A/C unit. Is the low side cold and high side hot like an automobile. I am low on freon and need to put some in. My on line is all iced up is that the low side. Before installing freon do i need to shut the unit off and let the ice disapear from on the line.
Old 04-25-09, 08:57 PM
B
1. You might try posting this in the Air Conditioning area rather than in the electrical area...
Air Conditioning - DoItYourself.com Community Forums
2. If you have to ask this question, you probably should not attempt to do this yourself.
3. Do you know what type of refrigerant your home A/C uses? (R11, R22, R-410A, R-134A, R-407C)
Old 04-26-09, 04:41 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Because you need to be certified to work with refrigerants we do not offer or support DIY sealed system A/C work.
It is a requirement that you find and have the leak repaired before adding refrigerant.
Read this.
