mars universal timer
Old 05-21-09, 08:45 AM
B
i have to tap on this timer to get my ac going.
i have purchased a new on online.
can i bypass this timer temporarily while i wait for my new one?
Old 05-21-09, 09:30 AM
dun11's Avatar
Received 1 Upvote on 1 Post
Sure............but it sounds like you just have a loose connection on the timer. Why do you even have your system on a timer?
Old 05-21-09, 09:52 AM
B
not really sure why the timer in on there, was on there when i bought the house.
it is just a delay timer
you can copy and paste 190261863818 into ebay and that is what is on my system.
Old 05-21-09, 10:17 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Hmmm..until an HVAC Pro weighs in....I think maybe that timer is to prevent short cycling of the compressor. In other words..it won't let in turn on right after it has turned off. Pretty sure that can cause damage to the compressor.
It may be that the contacts for the adjustment are dirty or have arced and burned a bit.
Have you tried rotating the settings through their full range several times (with power off) then set them back to original?
AGAIN..not a Pro here...but that wouldn't hurt I don't believe.
I wouldn't be bypassing it until you hear further...
Old 05-21-09, 11:00 AM
dun11's Avatar
OK, a time delay is very different then a timer. Its purpose is to delay compresor start up so your not starting against high head pressure.
You can remove it if you want until you get a new one
