Goodman U-32 Drain Tray Melted
Old 05-26-09, 11:12 PM
I have purchased a home in Jan. THis is the first time I ran the A/C. I notieced water around the indoor furnace/coil unit. I had to cut the side to look at the A-coild. I noticed the plastic tray was totally melted. Probably due to a filter not being changed...
I am trying to find a new tray. I can change this easily myself. Where can I get one??? ONline???
The tag on the outside of the a-coil is:
Goodman U-32 Rev A
S/N: 9702051820
Part No. 15346-09
Old 05-27-09, 04:33 AM
dun11's Avatar
Received 1 Upvote on 1 Post
Do you have an A-coil mounted on top of an oil fired furnace?
Old 05-27-09, 07:31 AM
It is on top of a natural gas fired furnace.
Old 05-27-09, 08:19 AM
dun11's Avatar
You can more then likely find one on-line, however that pan should not have melted. You may have a more serious problem, I would advise you to have a good local HVAC service company take a look at the system.
Old 05-27-09, 02:38 PM
Well, i think it has everything to do with the losers who owned this place before me did not change the filter. It was evident that the previous residence did not know anything about basic home maintenance. The furnace worked perfectly all winter. However, when I turned on my A/C the first time, i noticed no water coming out of the drain, and water around the base of the unit. That led me to investigate. I found the melted tray.
So, I need to know a good source for this online. I have looked, and could not find anything.
Thank you.
Old 06-27-09, 11:47 PM
B
Still looking?
I had this same issue happen to me (melted pan). Were you able to find the part?
If not, I got mine through Federal Heating here in Denver, CO
They can ship it to you if you need it. Part #B1755913H
Give them a call 303-934-7832
$56 bucks
