water leaking from bottom of furnace....
Old 05-27-09, 11:36 AM
I have a bungalow house that sits on a crawl space so the furnace & a/c unit is up stairs. A new furnace was put in February 2001 without a/c. Last May I had central air put in & everything worked great. It was hot here last week in Michigan so I turned the a/c on. The next day I noticed the paint in the ceiling below the furnace was sagging & filled with water. I went upstairs to find out what was wrong & noticed that the line from the little pump that pumps the condensation water from the a/c was bone dry. The pump has an access hole on the top & you can see there is water in it. I messed around with the pump & tried to take it apart & it kicked on. So... my question is; do you think something came apart inside the a/c unit or did the water backup & leaked from inside the furnace? There was no sign of water around the pump; the water definitely came from inside the furnace on the opposite side from where the pump is. Any ideas?
Old 05-27-09, 11:52 AM
dun11's Avatar
Received 1 Upvote on 1 Post
Either the condensate line is clogged, not piped right, or the pan is cracked.
