System will not shutoff when temp is reached
Old 06-12-09, 06:31 PM
T
Unhappy System will not shutoff when temp is reached
My upstairs system will work fine but when the set temp is reached the handler will shut off but the outside part will not until i switch it to off on the thermostat. The system is only 2 years old and is a tempstar. Any help is appreciated.
Old 06-13-09, 05:22 PM
pflor's Avatar
I suspect that you have a bad board, but it could also be the thermostat.
Please try posting the full model numbers for your equipment (both, outdoor and indorr units) as well as the thermostat..
I am particularly interested in seeing posted the model number of the indoor unit and thermostat.
Old 06-14-09, 03:39 AM
T
OK it worked a little while yesterday and did what it was supossed to but then the problem reacurred. The model of the unit is Indoor: fsm2x3000a Outdoor: n2h330aka100
The thermostat is a Braeburn Model 5200
