one room hotter
Old 06-19-09, 08:31 AM
F
one room hotter
i have one room hotter than the rest no leacks in ducts and add insulation to attic but i am think the vents above the doors will cure problem need info on vents and if this is the purpase of these vents
Old 06-19-09, 08:50 AM
dun11's Avatar
Received 1 Upvote on 1 Post
What vents above what doors?
Can you post a picture?
Old 07-28-09, 03:29 AM
F
it is code for new homes to have a return in each room but to get around having to install a duct and vent in each room they just put a vent above the door that goes through the wall one vent on each side of the wall above the door
Old 07-28-09, 05:22 AM
D
If you leave the door open does the room get cooler? If not. a return vent isn't going to help. You would need to reduce the heat load in that room or get more supply air into the room.
