Trane XL19i
Trane XL19i
I have a Trane XL19i 5 ton split heat pump with strips, live in north east MS with a Vision Pro IAQ T stat. I want the first stage on A/C to run the max amount of time to get the moisture out of the air currently 95f 67 % humidity outside, 72f 57% humidity inside. Water is a constant drip on the drain and I have a dehumidifier running inside that I empty 1-2 times every 24 hrs. House has crawlspace with vapor barrier on ground, duct work is in attic. The unit is constantly switching low / high / low / high......and I know the switching is killing my electric usage. Any help is appreciated.
Thanks,
Jimmy
Thanks,
Jimmy
