tall, narrow crank out windows=a/c? yes?
Old 06-24-09, 06:22 PM
How can I put an a/c into a bedroom that has only crank out windows, each one being 50" high and 21" wide? The crank out windows are on either side of a large picture window, and this room is stifling hot when the morning sun beats in.
Old 06-24-09, 06:26 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
Do NOT take this as a referral. It merely is to demonstrate what I am talking about.
Casement window air conditioners. They are tall.
Walmart.com: Haier Vertical Window Air Conditioner: 8,000 BTU: Home Improvement
Old 06-24-09, 06:31 PM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
You might consider a heat reflective window film such as those from 3M or Gila.
Old 06-24-09, 06:36 PM
B
Received 47 Upvotes on 43 Posts
The problem with crank-out windows is rain. I installed an ac unit in a side slider with a similar problem. I built a frame and support for the ac unit with a piece of plexiglas around it to fill the opening. It worked.
Bud
