Wiring advice w/pics :)
Old 06-29-09, 03:45 PM
C
In this link you will see what I currently have and what I am trying to go to....could somebody please be kind enough to advise me?
thermostat Photo Gallery by grinchy247 at pbase.com
Thank you all so much for the help
Old 06-29-09, 03:55 PM
D
Do you have a heat pump?
xxxxxxxxxxx
Old 06-29-09, 04:02 PM
C
xxxxxxxxxxx
I have central heat and air if thats what your asking...
Old 06-29-09, 04:15 PM
D
what kind of heat?
xxxxxxxxxxxxx
Old 06-29-09, 04:29 PM
C
what kind of heat?
xxxxxxxxxxxxx
sorry...here is a pic of air handler and ac unit....hope this helps btw I live in florida and might need heat 4-6 days a year
ac__air_handler Photo Gallery by grinchy247 at pbase.com
Old 06-29-09, 05:27 PM
C
please forgive my complete and total ignorance when it comes to this...
Old 06-29-09, 05:56 PM
D
I have lived all over florida before. It looks like you have a heat pump or electric heat, but I think it's a heat pump [reverse cycle a/c] because of the jumper wire between X2 and W and the wire on O terminal. Does the existing thermostat have an emerg heat switch? Can you tell us about the new thermostat? For example the brand and model #?
Old 06-29-09, 07:49 PM
C
sure it's a LUX TX9000TS...I dont see a/an emergency heat switch on the unit at all
Old 06-29-09, 07:59 PM
D
I looked it up at the LUX website. I cannot be used for multistage heat pumps. Can I see a pic of the part you removed from the wall [the piece with the glass mercury bulbs] and also a pic of the rest of the device on the wall? Thanks. I don't think you'll be able to use that Lux thermostat.
Lux - Programmable Thermostats: TX9000TS
Old 06-30-09, 04:32 AM
C
Old 06-30-09, 06:27 AM
Jay11J's Avatar
That t-stat will not work with your system.. YOu'll need a multi stage t-stat like Honeywell RTH7500, or RTH7600.
Why change of t-stat?
Old 06-30-09, 08:51 AM
C
want to be able to program it when to come on throughout the day/weekends....etc....ok so no go on this one so the other 2 you listed will work?
Old 06-30-09, 09:08 AM
Jay11J's Avatar
The Honeywell's will work.
How much of a temp change are you plan on setting up/down with the new t-stat?
Old 06-30-09, 03:10 PM
C
10 degrees....so in buying the 7500 or 7600 honeywell....what would my wiring hookup look like?
like red to r...blue to b...etc....
Old 06-30-09, 04:40 PM
C
can anybody assist me please?
Old 06-30-09, 04:48 PM
C
here is what new backplate looks like:
Picture 004.jpg photo - grinchy247 photos at pbase.com
If anybody could please tell me where my exsisting wiring goes into this...I would really be thankfull and so would my wife
Old 06-30-09, 05:20 PM
C
not trying to burden or be a pest....but tell me if this looks right:
WIRING.JPG photo - grinchy247 photos at pbase.com
if so where does "T" wire go?
Also I see a Black Wire on "X2" connected to "W" what do I do with that...?
Old 06-30-09, 06:30 PM
D
Looks good. You can dispense with tan, just tape it off. Install the black jumper wire from W2 to E. Good job on getting the blue wire in the right place, that's the one that causes problems on Trane units.
Old 06-30-09, 07:13 PM
C
ok hooked up exactly like that and blowing hot air (not cold but luke warm) I see some settings in the manual about selecting right heat pump type...seen here:
http://customer.honeywell.com/techli.../69-2104ES.pdf
pages 18-22 is what I am stumped on...what do i select? wife is yelling pissed at me (((((
Old 06-30-09, 07:23 PM
Jay11J's Avatar
Ok, for the system set up.
120 to 150 pretty easy to figure that out.
170 to 7
180 to 1 (I'm guessing you have electric back up?)
190 to 0 (If you are getting heat in the vent on cool mode, then change it to 1)
240 to 3
270 to 3
300 up 0
320 to 0
330 to 2
500 to 2
530 to 1
640 to 12
6
  #21
Old 06-30-09, 07:47 PM
C
170 to 7
240 to 3
270 to 3
300 up 0
320 to 0
330 to 2
500 to 2
530 to 1
640 to 12
6
VOILA! Perfect! Works great...thank you so much for the help....u have saved my life and marriage Beer 4U2
  #22
Old 06-30-09, 08:16 PM
Jay11J's Avatar
Glad to help out at the end. Didn't want you ending up in the dog house tonight!
  #23
Old 06-30-09, 08:40 PM
C
If you ever need help with computers let me know....alot smarter with that I knew my wiring had to be right...just was'nt 100% clear on programming etc...
again thanks alot!
Christian
