A/C filter has a sheet of ice
Old 07-17-09, 10:57 AM
Angry A/C filter has a sheet of ice
Please help. I have a Goodman A/c in my condo and the A/C stopped working and I noticed the filter has a sheet of ice on it . I removed the filter and the A/C is working fine without the filter.What could the problem be.!!!
Old 07-17-09, 11:54 AM
dun11's Avatar
Received 1 Upvote on 1 Post
When was the last time you changed the filter?
Old 07-17-09, 12:34 PM
About 2 weeks ago. The filter is clean .
Old 07-17-09, 01:56 PM
D
Did you replace the filter with the exact type?
If the same filter, is it pleated or of a high MERV value? Does your indoor blower usually blow more air in cooling than heating?
If your cooling air is greater than heating air, there could be an airflow problem.
Where is the filter located (and orientation) with regard to the blower?
Delta
Old 07-17-09, 02:11 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Maybe its a terminology thing...but has anyone ever seen ice on a filter? Aren't they normally quite a distance from the coils?
Old 07-17-09, 08:21 PM
On careful examination I have found that the suction pipe is frozen as well the the coils. I just had the servicing done on this unit and they checked the gas and it was fine about 2 months ago.Probably that is due to a leakage of gas.
Old 07-20-09, 05:43 AM
dun11's Avatar
It very well could be low on charge, I wouldn't run the system till you get it checked
