A/C Blower Motor Mount
Blower fan making a racket so I pulled the squirrel cage out and one of the motor mount screws was being held only by the rubber mount. So thinking I could replace the screw I tried to take out on of the good ones. Well, I can't get it all the way out or back in. Suggestions please.....
Often the little flat nut on the inside of the housing breaks loose from it's tack weld. I drill them out and use a bolt, washers and a nylock nut. If you use lockwashers and a standard nut it will come loose.
