Condensation - Drip Pan Issue
Old 07-26-09, 03:52 PM
Hello,
I have a Trane TWV036a140a0 and am having condensation drip problems. The drips are coming from a small 1/2" pvc tube exiting the side (maybe an overflow from the drip pan?) The plumbing seems fine from the two primary exits from the drip pan out the floor. I have an open t connection in the plumbing after the two exits from the pan and before the p-trap and don't believe this is correct. If I cap this open t, the condensation seems not exit the side 1/2" tube. I can also pour a water down the open vent between the p-trap and the main drain that is outside the presurized area where the open t is and it drains fine. I don't think the drip pan is backing up since I have not seen any unusual overflow yet since capping the t. Should I keep this cap on the open t in place? Is it supposed to be open? Any thoughts or suggestions would be welcome.
I can snap a couple of pics if needed.
Thanks,
Scott
Old 07-26-09, 04:27 PM
D
The pipe should not be vented before the P-trap because that negates the traps function. Venting after the trap for flow is ok. I'm thinking maybe the tee ahead of the trap might have been intended as a cleanout.
The pics would help other readers if you feel so inclined. Thanks.
Old 07-26-09, 05:25 PM
Daddyjohn,
Thanks for the info. I'll go ahead a run with the cap. Here are a couple of images...
Trane HVAC pictures by smachado1 - Photobucket
Thanks,
Scott
