AC Condenser installation
Old 08-07-09, 01:53 PM
B
If I pour a pad or use a insulite pad do I have to try to match cond to coil height? How important if within 6-+ inches?
Also, what the best way to secure the cond?
Thanks
Old 08-07-09, 03:38 PM
K
If you are asking if the condencer [outside] and evaporator [inside] need to be level with each other..no.The installer should know the max difference between the two.
Old 08-07-09, 06:01 PM
Jarredsdad's Avatar
You could pour a pad or use a premade plastic covered styrofoam pad. That's up to you. THe important thing is that the condenser is level on the pad.
As far as hieght above or below the evap coil.... Try reading the installation instructions. All those answers and much more is contained there in.
