Help ASAP...
Help ASAP...
Heres the back story; Was cutting vines down around the A/C unit outside to clean out the coils, when I hit the brown wire (Thermostat) running to the unit; The wire didn't split or break but pulled the connection away from the wire comming off the contactor connection; Thinking it was a simple fix I used a wire nut and reconnected the connection; Nothin... I followed the brown wire all the way through the craw space in my house to the blower unit and there were no splits or breaks in the wire. I went back to the unit outside and fiddled around w/ the contactor, when I push the center connection in on the contactor where the thermostat closes the curcuit the outside unit kicks on. But nothing happens to the blower motor in the basement. The ASAP part in the title is due to the cookout I'm having this afternoon and need to get this fixed befor then... Please help, Thanks
