Trane XE 900 - condenser fan
Old 08-12-09, 12:52 PM
Cool Trane XE 900 - condenser fan
The blower in the condenser unit is on all the time. I can set the thermostat to off and it continues to run. I changed the thermostat and no effect. Any ideas would be helpful.
Old 08-12-09, 05:03 PM
Skip4661's Avatar
Are you referring to the inside or outside unit.
Old 08-13-09, 06:29 AM
This is the unit inside the house in the attic connected to all of the room vents.
Old 08-14-09, 10:53 AM
Skip4661's Avatar
The inside unit is known as an air handler which contains the evaporator. The condenser is outside. As far as the problem goes, I suspect you lost your low voltage, 24v, power. I would start with the inside unit. Look for a blown fuse on the circuit board, is usually a purple, 3 amp, automotive type. If there is a fuse and it is ok, you will need to check the transformer output with a multi-meter.
