Capacitor and Contactor (p282-0311)
I ordered the capacitor and contactor and they came today. I was able to install the capacitor but a bit confuse on the contactor since the new model replaced the old model. My questions are in the pictures and if you could help, I would appreciate it.
Also, how often do I need to get service to pump freon into my AC?
First Picture: Where does the blue and brown wires go on the new contactor? The new contactor has the prongs on each side rather on the same side like the old contactor. The blue and brown wires right next to the question.
Second Picture: Is the old and new contactors set in the same direction correctly? I am not sure if I install the new contactor as you see in the picture or is it upside down?
http://i149.photobucket.com/albums/s...ofDSCN3815.jpg
http://i149.photobucket.com/albums/s...ofDSCN3831.jpg
Spin the new contactor, put the blue on one side and the brown on the other. You should never have to have refrigerant put in the system, if you do you have a leak.
Lastly, thank you for the refrigerant info.
Thank You
Does it matter which side the blue and brown goes?
Thanks dun11.
Just hope you can shed some light for me with a couple more questions. AC thing is all new to me.
Is Capacitor and Contactor common to go out after a few years?
What other parts in HVAC will need to be replaced from common wear-n-tear beside the Capacitor and Contactor?
My system is since 1991. Will my AC need to be replaced sometime down the road?
When you said "Spin the new contactor", you mean that I had it upside down in the picture right?
Thank You for helping me on this.
Other then the cap and contactor, anything electrical will fail do to normal ware and tear. Motors, compressor, boards, etc.
Your welcome...................
Dun, I installed and it worked. Everything much cooler.
However, a bit louder than before. There is no new noises but the operation of the unit is much louder. I am wondering if that is from me cleaning the fan or is it the new parts which I don't think it is the new parts since they are electrical.
BTW... Had I installed the contactor upside down, what would had happened?
Thanks DunBeer 4U2
Thanks DunBeer 4U2
Dun, I installed and it worked. However, a bit louder than before. There is no new noises but the operation of the unit is much louder. I am wondering if that is from me cleaning the fan or is it the new parts which I don't think it is the new parts since they are electrical.
It is not the fan. It sounds like from the new parts.
Received 0 Votes
Just replaced same model contactor. Now have no power to t-stat. I can manually depress plunger and the fan and compressor start up okay so it seems that a new contactor was my original problem.
Any ideas on t-stat power? It worked fine before shutting power off. Checked fuse inside blower in attic and it is okay.
Do you have 24v on the secondary side of the transformer?
Previous Thread
Next Thread
