Compressor works but fan will not come on
Old 08-18-09, 07:47 AM
P
My air conditioner is working buy the circulating blower in the furnace will not come on (with switch in auto postion or on position) However, if I put the heat on the blower does come on but when I switch back to cool or turn the heat off the blower will run for a minute or so then turn off
Old 08-18-09, 08:23 AM
dun11's Avatar
Received 1 Upvote on 1 Post
You may have lost the high speed winding in the motor, do you have a meter and know how to use it?
Old 08-18-09, 08:45 AM
P
Yes, I am not getting a reading from the cool but am getting one from the heat. I am getting a reading from the heat in a minute or two after the flame comes on even with the t-stat turned to on (not auto)
Old 08-18-09, 08:56 AM
dun11's Avatar
I am not sure what your trying to say, where are you taking readings and what are they
Old 08-18-09, 09:26 AM
P
Sorry, I am testing where the wires coming from the blower are connecting to the controller. Getting a 120 reading
Old 08-18-09, 09:53 AM
dun11's Avatar
Turn off power to the system and chk the high speed lead (the one for cool) for a shorted or open winding.
Old 08-18-09, 01:36 PM
P
Can you walk me through how to do that?
Old 08-18-09, 02:58 PM
P
I ran a jumper from the line in to both the high and low speed wires and they both worked (blower came on). Does this mean the controller is bad?
Old 08-19-09, 08:30 AM
dun11's Avatar
It could be, I am still not sure what exactly your checking. Does the "controller" have a fuse on it?
Old 08-23-09, 03:04 PM
First off; what is the make and model of the furnace and thermostat?
