Water leaking from AC inside furnace.
Old 08-18-09, 11:06 AM
T
My tenant has noticed water coming from within the furnace/AC in the basement. I believe its the drainage in the coils that are clogged? Is this easy to get to so I can just clear out the drain? The furnace is old..maybe 20 years. Is there a top panel that is screwed in or do i have to remove the duct work to get to it?
Thanks,
Tony
Old 08-18-09, 09:19 PM
C
Received 8 Upvotes on 8 Posts
Need more information about your unit in order to help you. Did you see the drain pipe ? one or two ? A picture will help a lot..
