A/C Electrical
Old 10-10-09, 05:02 AM
W
A/C Electrical
I have an interesting problem. My heat wont turn off at set temperature. Checked wiring at thermostadt and Honeywell controller. This is a new house, it was working fine through the summer and into the fall, it was cooling fine and heating fine and them one night I woke up to 90 degree temps in the bedroom. Any ideas?
Old 10-10-09, 06:44 PM
Jay11J's Avatar
Did the heat turn off when you switch the t-stat to "OFF" mode?
What happen when you turn it back to heat?
Old 10-10-09, 08:07 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Do you have gas or electric heat?
Electric heat squencers can cause this...
Old 10-11-09, 06:52 AM
a new house the unit will have a warranty 2 yrs from the builder
Old 10-13-09, 11:11 PM
C
I guess you solved your problem otherwise it would be mighty toasty in your crib by now.
