A/C Condenser fan motor does not work
Received 0 Votes
My Janitrol A/C external condenser fan motor does not work. When I use a stick to propel the blades it then starts running. I think it is the capacitor that I have to replace but I can't seem to locate it. The motor is GE motors Model: 5KCP39EG. Is this a capacitor issue and where is the capacitor?
Thanks
Ganrao
Thanks
Ganrao
If the blade spins freely with power removed it is probably your capacitor.
Your cap should be in the control panel. Do you have a 5/16 nutdriver? It is probably connected to the fan motor with a brown wire.
Be cafeful with caps, they can hold a chrge for a few minutes after removing power.
Match voltage and microfarad.
If you have a dual cap match both microfarad values and voltag. Be sure to write down the existing wire = terminal combination before removing any wires. Color codes vary.
An example of a swollen 5mfd, 40mfd 370 vac dual capacitor...
A 5mfd 370vac capacitor...
