wiring t-stat to heat pump
Old 01-06-10, 10:54 AM
Last year I had my a/c condensor replaced with a heat pump/condensor. The air handler has a heat strip and the t-stat was hooked as the old system was. I would like to rewire with a honeywell rth3100c stat so that the heat pump is the source of heat NOT the hest strip.I will run new wiring as needed - What gets hooked up to what?
Old 01-08-10, 08:48 PM
Houston204's Avatar
Received 83 Upvotes on 76 Posts
http://customer.honeywell.com/techli.../69-1889EF.pdf
The RTH3100C will only work as a heatpump stat.
It will energize Y (compressor ) on demand for heat or cooling.
