Changing Thermostats
Old 03-21-10, 02:49 PM
P
Question Changing Thermostats
I have a trane unit with a Baystat240 thermostat. Ther wires are red (r), brown (t), orange (o), green (g), yellow (y), black (x 2), blue (b) and white (w). I want to replace it with a Hunter 44860 which has r, c, y1, y2, w2, e, o, b, g and l. How do I wire this up properly? Thank you for any help.
Old 03-21-10, 03:02 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
RH & Rc/R = red (use a jumper wire)
C = blue
Y1 = yellow
W2 = white
E = black
O = orange
G = green
Tape off the old brown thermister wire.
You must also configure for heatpump operation as described on pages 28 and 29.
Old 03-24-10, 04:42 PM
P
OK. First off, thank you for your reply. I now have it hooked up just as you replied (except of course it is programmed as a heat pump and not conventional).
That being said, the fan will not shut off. Did I do something wrong or is it a programming thing I missed?
Old 03-24-10, 05:47 PM
Houston204's Avatar
1. Recheck the wire on G (fan). Is it shorting to R (power)?
2. Many air handler have a sequencer (timer) for the fan which will have a delay before the fan turns off.
